Electrical Help, fuse panel
supraman502
not lazy, just dont care
Apr 8, 2005
326
louisville, KY
Picked up a 89 turbo /auto
Quite a few electrical issues, Not working (interior lights, gauge lights, climate control lights turn off when headlights are on, warning lights, rear wiper, fog lights,brake lights, etc)
Car was a electrical nightmare, the previous owner had quit a bit "rigged" together. Cleaned up the wiring to start repairing things correctly, new cluster fixed the warning lights, new dimmer switch fixed the dash lights and climate control issues.
My issue at the moment is, looking through the engine bay wires for any cuts / unhooked wiring, I noticed on the fuse block, the ALT fuse had to power wires coming from the bottom and one of them was cut off, I'm wanting to know where these 2 wires go, I attached a pic, but I had already taped up the cut wire.fuse.jpg
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
and
So one to the am1 fuse and the other to the 10mm on the alternator (12mm if you got the 100a alt)
