OK... With just the Engine, the Engine Harness, the ECU, the Transmission... Can I use the Factory ECU and the Factory Engine Harness and the Motor Run Properly? Gauges and all that is later... Everything from Under the Hood of my MK3, even the Diagnosis Plug, the Factory Engine Harness with the Engine, and the Factory ECU, will it Start and Run?
