E30 Ethanol Blend
landtoy80
146
grand junction, CO
There was a study on E20 and E30 Study Finds Certain Ethanol Blends Can Provide Better Fuel Economy Than Gasoline | Auto Newswire Article from Motor Trend and it showed E30 offered better fuel economy than gasoline (a 1% increase) in both the Toyota and the Ford that was tested.
http://www.motortrend.com/features/newswire/33057/index.html
Anyone try a blend of Ethanol in the Supra?
Will I have to do any changes to the car if I run a E30 blend?
All gasolines contain ethanol now (in the US), it's used as an octane booster.
I don't know how the hell they got their data because ethanol has less energy than gasoline...
gaboonviper85
3,236
Northeast Philly
dazzle them with brilliance or baffle them with bullshit......for this thread i pick the later!
figgie
Twin Cities, Minnesot-ah
the other issue
E30
none of the older or even newer ecu will adjust for that.
15% tops but 30? Way out of the range of the O2 delta control. Usually plus minus 15%
now back to mpg
the ONLY way i can see this happening if they take the Diesel route and make a motor that is 100% made for E85 with no thought of ever using gasoline. That means ultra-high compression 12:1 and up, big injectors specific to E85 and ultra-high fuel pressure along with lean cruise.
Yep, but even in that case you're still working with less energy to burn, that's why diesels can get amazing gas milage.
There is only so much energy in the fuel...
Fozbo
7M Love
Apr 4, 2005
290
Norman, Oklahoma
Gasoline has roughly 125000 btu in a gallon and ethanol has about 85000 btu in a gallon, basically gas stations are watering down their gas. Besides, I bet that 1% difference resides is a 2% or greater error in the recordings and/or calculations, making the difference have no real value or meaning at all.
figgie
ahh but energy is only part of the equation.
The other portion which is very important is the combustion efficency and that is where alcohol has always had a huge efficeny advantage. Lower combustion tempratures along with a slew of other things can make ethanol get better MPG than gasoline but as i said before. The motor MUST be 100% designed around ethanol and with 0% useage in gasoline.
figgie
Poodles;1082200 said:
Exactly, there just isn't enough energy in it to do the same amount of work more efficently.
It's scientific fact...
no it is your opinon.
The process of Alcohol (ethanol) to CO2 + H2O is more efficent than when using a hydrocarbon. Hence why the heat is no where near as high when using Alcohol v a hydrocarbon based gasoline.
