dyno with vid 74-75.96ar
quake
toyota tech
Apr 13, 2005
619
r.i.
so went back to the dyno as an update. Last time i maxed out the map sensor and had a hard time fixing the tune as i had misfires. This time i have a vid and no sheet lol. Ended up around 760rwhp and 650tq on 30psi ran out of wastegate spring. I installed a weaker spring to stay within the range on the map sensor.
93oct + meth
os giken triple
7mgte built
1000'cc injectors
custom 3.5" exhaust
http://www.youtube.com/watch?v=5LJ2B9Bqe7U&feature=related
http://www.youtube.com/watch?v=CezKAtDrDGk
quake
toyota tech
Apr 13, 2005
619
r.i.
thanks
---------- Post added at 01:06 PM ---------- Previous post was at 01:05 PM ----------
Supra28;1716824 said:
Amazing, love the way big single turbos sound.
Just realized you're in R.I, what part of town? If you don't mind me asking.
providence
---------- Post added at 01:07 PM ---------- Previous post was at 01:06 PM ----------
sous;1716822 said:
really nice number sound awesome congrat 7mpower
thanks
quake
toyota tech
Apr 13, 2005
619
r.i.
just checked the mani and found a crack in it lol i was actually happy free power i'll take it. New numbers soon with the new ecu and more boost.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
sort of off topic, how stiff is that OSG clutch? I was looking at buying an OSG twin or triple for when I do a big power build.
quake
toyota tech
Apr 13, 2005
619
r.i.
less than my act extreme, just get ready to break trannys and relearn how to drive stick lol
quake
toyota tech
Apr 13, 2005
619
r.i.
Moy;1717328 said:
lol. on/off switch and what do you mean by breaking trannies?
it's not really a on off switch, when you first get it it seems that way and you will stall alot. after about 500miles it is much better and very smooth till you get it hot. As for trannys if you need a tripple or twin clutch you are making the kind of power that breaks trannys if you use the car.
---------- Post added at 09:33 AM ---------- Previous post was at 09:30 AM ----------
NashMan;1717365 said:
nice nice so were is this dyno graph
printer was down so dont have a sheet however if you search my name it pretty much looks like the last one. Last time i could not finish the tune as i had break up. This tune was it for 30psi. Time for a new cam and more boost then nos.
---------- Post added at 09:33 AM ---------- Previous post was at 09:33 AM ----------
yota8791;1717367 said:
great numbers, way to rep 7m's, which coil packs are you running?
msd
quake
toyota tech
Apr 13, 2005
619
r.i.
NashMan;1717466 said:
fair eghouhg how fat is you power band seam large
4500 to 6500?
used to be 4400 a bit later now but i need to play with timing a bit. Top end is 7500 -8200 depending on my mood. A pull in 4th to 7500 puts you over 130 or so. Its actually to fast for the street but i am crazy. Open gate and 3.5" exhaust means no hiding it at full throttle you can be a 1/4 mile away and still hear it.
yota8791
242
virginia
i gathered they were msd, but are the ls1 coils or what is what i ment, i should have worded my question different my fault
quake
toyota tech
Apr 13, 2005
619
r.i.
NashMan;1717680 said:
^ so 2000 to 2500 rpm of power ?
more like 2700-3300rpm of big power the average supra still wont keep up if you throttle it for only 12psi to redline
---------- Post added at 08:33 AM ---------- Previous post was at 08:31 AM ----------
go to the web site it's the gm 2 tower only one
polobai
Orlampa
siiick numbers-have you put it on the track yet? Im curious to see what times you put down and how laggy the 74mm is on the tarmac...also trap speed?
