hey, so ive just rebuilt my 7m, its going good, feeling smooth and its responsive
my mods are,
BC valve springs
3" cat back exhaust
FMIC with hard pipes
electronic closed loop boost controller
engine balanced
anyway my boost drops with higher rpm under WOT, the stock dump elbow looks restrictive and im using a stock cat as well
planning to ditch the stock dump and get a custom one made up.
watch the blue digital gauge at the bottom, my missus was filming so she kinda took it off frame after a few seconds but you can cleary see it drop to 5psi. round 5500rpm
with the boost controller disconnected boost does not spike, hits 5.8 smack on and sits there, not sure if it drops round 5000rpm
im really just seeking confirmation that the exhaust is causing this drop in boost, as it did the same thing with 2 diffrent MBC's.
no fuel smell, no black clouds out the exhaust, does not feel like its running rich or like there is a boost leak. absolutely no error codes either.
http://s29.photobucket.com/albums/c295/paradox616/?action=view¤t=run01.flv
my mods are,
BC valve springs
3" cat back exhaust
engine balanced
