Driftmotion Turbokits
SupraClaou
846
4
Athens,Greece
Man.....I hope the 2JZ exhaust manifold to sit without any 'banging' and
mods to the A/C lines or the frame/chassis :sarcasm:
I hate 'hitting' my car....Allready did it when I put the 2jzgte with the stock
twins.
But,your DM67 turbo kit install looks great at the end!
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
DP mocked up to check out fitting
Fender side view
Manifold side view. Notice how the coolant pipe is bent up. I just moved it w/ a pair of pliars. The cap was filled with JB Weld and put on there waaay back when I put on my GT28R twins.
Needs to be moved a little more...
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
93supraTT;1264794 said:
looks slow :p
get r done todd so you can come out tomorrow....i threw my drag radials on today and got her goin a bit...
Still have to put on new fmic, get piping modded to work w/ said fmic, and have the midpipe made for the exhaust, as much as I don't want to lol
I might be out in the beater though lol
te72
Classifieds Moderator
6,604
WHYoming
Looks pretty good man. As much as I really like the idea of going with the PT6262, this is *almost* too good of a deal to pass on.
Oh, and my eyesight isn't the best this early in the morning, but that little coolant nub isn't touching the manifold is it? I don't see that ending well if that's the case, even if it is filled with JB...
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
the rubber part is, but that might get rebent or removed, that was just a quick mockup, since time is limited w/ the car right now. The dp will also be wrapped in header wrap.
te72
6,604
WHYoming
That's good, nobody likes random coolant leaks, particularly hard to reach ones :p
pnutcar
1jz Asshole :)
Jan 25, 2006
299
St. Louis, MO
Torque;1290893 said:
Hey Pnutcar, is that car up and running as yet? I would really like to know how responsive that T67 is.
Its not up yet, had a manifold issue, but me and Aaron got it all sorted out. I will be making a whole new write up when I get it on. Everything on the kit is good though, you won't be disappointed. I will be able to let you know how it is on stock cams and on 264s, but I won't have any dyno numbers unless ppl want to chip in for a few pulls lol
turbo87targa
482
colorado springs
this kit is still available for the 7m right?
Does anyone have it running on one?
If not does anyone know which ar would be best for good street driving? (I'll also have 268 cams to help)
I plan to be the 7m test pig of no one else has already done it.
