Alright I have a 7mgte that I rebuilt and added all sorts of goodies.
Walbro, 255s, lexus afm, 3 inch downpipe and exhaust, hx40 t4 turbo, external gate, boost controller, SAFC2 piggyback, 3 inch intercooler and piping, aeromotive AFPR, deleted EGR stuff, relocated alternator and did a front facing intake manifold. This is the throttle body I bought.>>>> THROTTLE BODY
First question, that throttle body SEALS, it has no place drilled out around the plate for air to pass around it while idleing closed....is that an issue? Or should my Idle air valve work and be compensating for that sealed closed throttlebody?
I have put a BRAND NEW t.p.s. on it and calibrated it with feeler gauges. per this writeup>> CYGNUS
At .879 feeler gauge (closest i had to .9) the signal was blipping back and forth from Infinite to .0050 and that's the best I could get it.
I put it on the car and I still have code 41. I also have 22 because I don't have the thermostat sensor hooked up right now.
The car wont start, just cranks and cranks and cranks. Does not change sound weather I hit the gas while cranking (throttle open) or throttle closed.
I have set the SAFC2 set to Karman,6, and upper right. I have the Aeromotive AFPR at 35lbs, I verified I the fuel pump is working by using a jumper wire. I have yet to check Spark. and I have yet to use the timing light to set at *10 because it wont run...But I'm thinking it has to do with this code 41.
Where to go from here?
