Dome Light Only Works When Doors Are Open
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
^ when my doors are opent he dome light will turn on *both bulbs* but with the switches the lights will not. Everything seems to be connected properly though. If it matters, I have to hold the 12V connector at a slight "up" angle to get the door light to come on. Thank you. and If it is the rivets, how do I take them out to put in new ones? thank you!
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
Diodes? Yeah it's real annoying the buttons don't work lol especially because with my luck night is always the time I need to read something!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I rewired mine without the diodes, so that the switch on the right controls both lights. I rewired the switch on the left to control aux power to an external device - GPS, Camera, etc. I also picked up a rechargeable LED flashlight that sits in the cig. lighter socket in case I need light elsewhere.
Rob_Supra87
87NAPWR
Aug 3, 2008
278
Millbrae
Diodes? yeah if I can't fix it by tightening the rivets I have no problem doing ^^^ since when I need the light I usualy turn them both on anyways....
