Doesn't seem to be all it should be
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
New Birgher Vid: http://media.putfile.com/0-60-cum
Is it normal for the 1990 na to be this slow? I know my shifting and launch could have been a lot better but what is the average 0-60 times for the NA? I counted almost 10 seconds, wich is as slow as the oldsmobile.
The only things I have are exhaust with no cat and new pipeing and generic cone intake. Seems like it should be a little quicker, maybe not.
Mob
190
Dayton, Ohio
Welcome to the world of a n/a 3500+lb car. I thought we talked about that? Also, make sure to check out the meet on the 21st bud.
ValgeKotkas
2,224
Over the pond
The stock 0-60 is what, 8.1sec? And you counted what, 10sec? And you have what, 16year old car? And you have what 150whp? And you have what, 3500+lbs? ;)
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Yeaah, I guess your right i just thought 8.5 sec wouild be possible. Too bad they don't make many practical performance parts for the GE. Thinking about it, i just might have to do a swap or just ditch the car for another one no matter how bad that sounds..
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
They make a fantastic performance part for a GE! It's called a Turbo!
If your motor is in good shape, go NA-T
If not, rebuild and go NA-T, or drop in a 7MGTE
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Ok...:nono:
I don't know about you but i don't exactly have the money to just drop a turbo motor in there right now.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
OfnaRcR4 said:
Ok...:nono:
I'm not made of money either, but over time I've saved up and i'm nearing completion of rebuilding a 7MGTE
You were the one complaining about how slow your car is!
Electric S
Suprattitude
Jan 22, 2006
23
Oss, Netherlands
Check this movie to see how slow my '88 Supra was
The car was bone stock @ that time
I've done a 7M-GTE swap a year ago
Do it if you can afford it... you won't regret it!!
Btw: The vid is pretty dark!
You may want to adjust the brightness of your monitor
s383mmber1
3,614
Somers New York
The videos not the best, and i can't see the speedo.
10 seconds is slow though. Mine was doing 7-8 ish. I did have a little bit more done, but not too much more.
Get it compression checked and report back here.
AND--
If you dont think your cars running right, do you think you should be flooring it? :aigo:
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i dropped a 7m-gte, re-built the head, got a whole list of parts as well and installed it in my car when i was 17 working for 6.25 an hour and was in highschool :dunno: just saying... it can be done
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
So your parents pay insurance and college right?
Anyway, what should i do to make sure it is running right. What are some little things to replace to help it run better. It seems to be running fine but i donno. Check engine light is on "from the motor swap" but i am thinking that its on from a loose sensor or something. I donno, check the origional post for a brighter vid.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I suggest searching around on here, and doing lots more reading here and www.cygnusx1.net
Check your error codes, solve them
Check and solve any vacuum leaks
Check your compression, if you can, do a leak down test
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
I pulled a code 52, knock sensor
52 Knock Sensor Signal
Diagnosis
Open or short circuit in knock sensor signal.
Trouble Area
Knock sensor circuit
Knock sensor
ECU
This bad, or will this slow it down?
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Alright thats a good thing and a bad thing. Good because now i know it can be quicker but bad because code 52 seems to be pissing a lot of people off. It would be nice if the sensor is just got disconnected and i can just plug it back in.
Edit, what are these unplugged things alla bout?
Also what is the metal thing in the second pic, its just kind of hanging there.
