Don't wanna hear (just get an lsd idiot!!) cause I have one I just tried doing some research and could'nt come up with anything anybody that knows where I can find one that'd be sweet that'd be sweet
Maybe i I had a mid 80's firebird I'd do thatjmanbball said:^^ Just take an open rear end and weld up the spider gears
Against NHRA rules..... I supose they would have to actualy look thoughjmanbball said:^^ Just take an open rear end and weld up the spider gears
jawsgear said:And here I am, praying that the welds are good and don't break as I am doing 100+ mph down the track. LOL
thesandymancan said:the problem isn't the weld, it's the cast iron that would break.
I don't think you can doesn't it completelty replace the differential??SnowMongoose said:Same as welded rear end, just that you can 'unlock' it.
nosechunks said:yes, the ring gear bolts to it and it directly splines to the axels, its a solid piece of steel or aluminum, no way to unlock it. exactaly like welded spiders but its 1 piece and designed to take abuse.
