do i need these? Name That Sensor!
cpederson
117
wi
im putting a supra 1jz into a 87 mk3 and have a question on thses sensors from the stock 7m. do i need these with the 1jz?
thanks corey
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
starting with the top left - no idea what that is
top middle - noise filter, you do need this if the 1J swap didnt have one.
top right - injector resistor only needed if you plan to run low impedence injectors. the other piece is for the stock boost gauge.
bottom left - no clue
bottom right - no clue
top left-fuel pump relay.
bottom right- fuel pump resistor? right side fender next to the fuel pump relay.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Yea the round connector is the fuel pump relay it haves a resistor also next to it for slow speed switching If you do the fuel pump mod you could toss the relay/resistor? been a while.
