Differential Fitment
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I dont see how this could get so messed up.
4.1 torsen is JDM and they shatter under load shock you could call them a glass diff.
In US models
86.5-89.5 they are 3.9
89.5-92 they are the much taller 3.7
NA models also had an optional LSD 4.3
So if it had front headlight squirters it had LSD,
but it was optional in the case of my old white 1987
it did not have squirters but it did have an LSD diff package.
Vin codes do not lie
read the 4 digit axle code
on the VIN plate.
G315
G means it is a 8" diff
31 means it is a 3.91 gear ratio
5 means it is a 4 Pinion LSD clutch pack
Other codes you will see on a supra
4 = 4 Pinion open diff
28 = 4.30
30 = 3.727
G299 in JDM vin codes
G = 8"
29 = 4.10
9 = LSD torsen
JDM plate will read
Model E-JZA70-BMLV
Engine 1JZ-GTE 2491CC
Frame No. JZA70-0013620
Color Trim
202 FK15
Trans./Axle R154 G299
Plant A53
I still have my JDM plate.
