Other than minor casting differences, there are 2 major 7M head variants.
And that is in the intake port.
Some have a long divider coming up from the valves,
and the other has no divider.
I think if you look on some of the other Supra forums like possibly supracelica,
you will maybe find the year break-downs on where they appeared over the years.
From what I read, the 'no divider' head is best for peak power & turbo applications,
and the head with the divider makes for better low & midrange power & NA engines.
Then, of course there is the Group-A head (very rare) that had less valve shrouding in the combustion chamber.
This is something people seem to forget about when they are trying to build a killer 7M.
The 7M has a shrouding problem around the intake valve.
By installing big valves this problem gets worse,
since the head of the valve is now closer wall of the combustion chamber.
When I put larger valves in my head, I cut the wall back by 1.5mm.
Then there is the little 'finger' that sticks down between each pair of valves that also interferes with flow into the cylinder.
On the Gr.A head, this has been eliminated, as it was in the later 1J/2J heads.
