Are the Lower ball joints the same on the 86 and 88 N/A front suspension?
supraman508 New Member Sep 19, 2007 496 0 0 maryland Nov 20, 2009 #1 Are the Lower ball joints the same on the 86 and 88 N/A front suspension?
cuel Supramania Contributor Jan 8, 2007 1,536 0 0 Baytown, Texas Nov 21, 2009 #2 yes. fairly easy to change, but I'd advise new ones, not used ones. Also, if you get the Moog brand, they'll have grease fittings.
spiller New Member Mar 5, 2008 582 0 0 Australia/Chicago Nov 21, 2009 #3 to answer your question, all A70 supras have the same lower control arm balljoints.
supraman508 New Member Sep 19, 2007 496 0 0 maryland Nov 21, 2009 #4 spiller;1456039 said: to answer your question, all A70 supras have the same lower control arm balljoints. Click to expand... Will i need the SST tool to pop out the joint?
Jeff Lange Administrator Staff member Mar 29, 2005 4,918 4 38 37 Calgary, Canada jefflange.ca Nov 22, 2009 #5 Thread moved. This had nothing to do with the 7M-GE. Jeff
