Dicktator ECU???
figgie
Twin Cities, Minnesot-ah
Yikes,
I am not to fond of an EMS that requires you hack the stock config to make it work (Making 24 tooth into a 6 tooth setup). Of course you could not use the stock CPS and make a chopper wheel with 6 equally spaced teeth and call it a day with no hacking of CPS teeth.
No memory logging so requires laptop be connected.
For 388 can not be to bad but it all depends in what is needed. Who wants to be the guinea pig? :)
jmcboost
Missouri
Yeah, I don't know too much about ECUs. I'm still trying to wire up my stinger. It's not too bad. I saw this and thought members would want to know it's out there.
