detonation or anomaly
isnms
United States of America
Oklahoma
i80.photobucket.com
These spikes showed up in my EGT signal. It hasn't appeared in any other logs I've been taking over the past few days.
I was in 4th or 5th gear, cruising. Seems to be at a time of off throttle, pink line declines.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
It almost looks like you would've been going down hill; but, your RPM's stay constant. It looks like a sudden loss of data/input because it starts to recover.
I doubt detonation. Could it be a loose connection...did you use wire taps for the install?
mkIIIman089
Ohio
At <10&#37; throttle I'd say it's impossible for it to be detonation. Might just be noise... IIRC EGT sensors are especially susceptible and what ever set of events you created there made it go squirrely.
It does seem a bit strange that RPM is so perfectly flat without knowing what you were doing. I doubt any of this has anything to do with power loss to the ZT-2 though, from my experience if it loses power even momentarily it takes a minimum of 15 seconds for it to reboot again. During that time no logging can take place.
isnms
Oklahoma
i80.photobucket.com
Thanks for the replies. I'm thinking some kind of noise or signal distortion. I've taken over 80 minutes of logs over the last few days, to and from work normal driving, and this is the first time I've seen this show up.
tissimo - What are the conditions/cause/ramifications of uneven burn at low load?
tissimo
Stock is boring :(
Melbourne, FL
uneven manifold distribution at very low velocity, uneven injector flow, improper tuning for those very low load levels.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
how many seconds elapse on the x scale on that graph?
Looks like noise to me. You weren't monitoring your timing by any chance were you?
