So a search shows me...
1) There is a difference in Toyota part numbers, and
2) The pump body is longer on the gte pump due to longer gears, and more pumping volume.
If you don't have one of each to compare body length, and you have an Aisin pump that you got from somewhere other than Toyota, how can you say for sure which one you have?
What are the specific lengths? What is going to be different in the markings or numbers on the pumps?
This is why I ask... http://www.supramania.com/forums/showthread.php?t=71809
So which is it?
So which is it?
