I love optima batteries... but recently I let my buddy borrow mine and he said that it wont hold a charge from his alternator and that he tried charging it and his battery charger wouldn't even start charging it ....
So I was board and had given up looking up "supra vids" on YouTube and googled my battery and this is what I found
I tried it and Presto believe it or not it worked battery charged and is working now
So i thought i would share
Sent from my C771
P.s. mods please move this thread if I posted in the wrong area or if it would be more helpful elsewhere thanks
Jim McIlvaine eCare Manager said:fintstone asked me to start a thread with instructions on how to recharge a deeply-discharged (below 10.5 volts) Optima battery.
Virtually any standard automotive battery charger on the market will charge an Optima battery just fine. However, most automotive battery chargers will not charge any battery that has been discharged below 10.5 volts. If a standard flooded battery is discharged below 10.5 volts, there’s not much of a chance that it will be serviceable again. However, AGM-style batteries, like Optimas, can be recovered from a deeply-discharged state, by using an AGM-specific charger or by parallel charging.
To charge a deeply-discharged Optima with a regular charger, you can wire a second fully-charged automotive battery (12V+) to the discharged Optima in parallel (+ to + and – to –. Then hook up the charger to either battery, setting the charger at 10 amps for 2 hours and monitoring it frequently.
When the discharged Optima reaches 10.5 volts or more, remove the second battery and continue charging the Optima until fully charged.
Typically we recommend charging at a relatively low current, such as 2 amps, but when a battery has been deeply discharged, some sulfation of the battery plates may have occurred. However, if you charge at 10 amps, the higher current will help to break up sulfation that may have occurred. If you have an automatic charger, let it run until the charger indicates charging is complete. If you have a manual charger, estimate charging time by multiplying the capacity (amp hours or Ah) of the battery by 1.2 for a rough estimate of charging time in hours.
In most cases, these steps will recover an Optima battery. It’s ok for the Optima battery to get slightly warm during the charging process, but hot to the touch or hissing from the battery indicates a short and the process should be discontinued. If you are able to fully charge the battery, but it gradually loses it's charge (without any loads on it) over 12-24 hours, the battery is probably not recoverable.
If you’d rather not deal with this process, you can always take your battery to a professional battery specialist, like Interstate, who knows AGM technology. Most of them are willing to provide “charge and check” procedures for a small fee and many will provide the service for free.
If you have any other questions, I’ll do my best to answer them. I appreciate your interest in Optima batteries!
Jim McIlvaine eCare Manager, OPTIMA Batteries, Inc.
Sent from my C771
