Damn this sucks.... AEM EMS V2 BOO!!
1986.5supra_kid
Rice? No its Corn (E85)
Ugh im glad i havent actually installed the aem ems v2. I was led to belive what i bought was e85 capable, as in flex fuel sensor capable. turns out i should have bought the proefi 128...
My goal was to be able to used pump gas or e85. on the fly....
so if anyone else did not know this heres youre sign!
Also whats a unused (still has seal over terminals) aem ems v2 worth? its the plug and play 2jzge for 1992-1997 sc300 and supra
1986.5supra_kid
so this update is already out?
I got the new firmware loaded and hooked up my FF sensor. I had E85 in the tank and took it down to mix some pump gas in. I have a pump gas map, but for this, I simply copied my E85 map to the petrol Fuel Map minus 30%. Blended it linearly from E85=100% to E10=0%. It got down to about E35 and O2 Feedback didn't have to compensate too much. Once I get this tank empty and get only E10 in there I can dial in that map perfectly. More to come![qoute]
Soon. It's really up to you, but if you're in the middle of a build, it will probably be out by the time you're done.
1986.5supra_kid
i doubt my fuel system is capable right now either.
400lph e85 approved (in tank pump) 600hp at crank is what the vendor says
850cc seimens
aeromotive FPR -6 an lines
the fuel line from filter to FPR is stock and the rail is stock too.
from what i have researched; the stock steel lines wont flow enough and the fuel rail on the NA 2jz doesnt either.
im guessing that ill have a limit of 470RWHP on e85.
IndigoMKII
2,181
Madison, Virginia
850cc seimens
You could always run the double walbro 400 or one of these. http://www.z1motorsports.com/350_g35/product_info.php?products_id=6403
1986.5supra_kid
emailed AEM tech support
Adam,
The Flex Fuel control is a feature in an upcoming major firmware/software
release scheduled in the next few weeks. It's currently in the beta
testing process and we're awaiting feedback from our beta testers. Once
the update is released, it will be available as a download from our
website for free, and the EMS can be updated through your computer.
Thanks,
Beau Brown
Technical Support
AEM Performance Electronics
(310) 484-2322 x251
www.AEMElectronics.com
