hey everyone, im wiring in my new ECU (megasquirt) and i need some clarification about what some stuff means.
in the following i am referring to here: http://www.supras.nl/index.php?option=com_content&task=view&id=34&Itemid=50
if you look at the defogger relay (M1 pin 11) it says signal is switched to mass. What does it mean when the signal is switched to mass?
also on connector M1, pin 2, it says "Plus for backup light switch". what is Plus?
thank you
thank you
