ct26 to t3 adapter for gt35r
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
My friend had a holset hooked up to his 7m with that adapter. Mind you the holsets have HUGE housings, took a lil banging but not much. As fas as clearing the oil housind , i blieve there shouldnt be any problem. OK $50 dollars against $200 plust fot t4 manifold then a t4 to t3 adapter. Just try it. ...
3.0 GT
2JZ Holset Mafia
Nov 30, 2008
381
Franklin, Tn
i use one for my holset setup (he351) and to fit my large ebay wastegate i had to make a little neck for the wastegate port which aimed the flange up and towards the head, grind some fins off of the wastegate, and i had to cut and weld to change the angle of the adapter more upwards because the turbo hit the shock tower. it was a lot of work but it works good now. if i had to do it again i would have bought tubular and thn a skinny t4 - t3 adapter.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Damn $700 for that manifold, i think you should just buy the ssautochrome t4 manifold and a t3/t4 manifold with an angle.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
:) 700 bucks NICK, hey ill post a pic of the manifold and adapter im talking about. Its tha one im using for my holset setup. Ill try to take a pic today.
