ct26 front oil seal failure
supraguru05
Dec 16, 2005
737
louisville ky
I just want to confirm the modes of failure for a front oil seal in a ct26 turbo. I have been through 2 ct26 turbos. one was rebuilt, except the center section wasnt machine and it blew the rear seal. i put on a used turbo i bought off someone and now it appears to be leaking out of the front seal since i have a ton of oil in my inter cooler, with normal blow by. my PVC setup is factory, however my oil pump is shimmed so my cold oil pressure is pretty high its >60 psi. I also have a NA block with a gte pump so my running flow rates are higher than normal. the turbo is fed off of the oil gallery with a -4 an line. is it possible to have to much pressure or flow?
MDCmotorsports
Indy 500
www.MDCmotorsports.com
The ct26 (hitachi) cartridge DOES NOT HAVE AN INTERNAL OIL RESTRICTION.
The subaru turbos (mitsubishi) do. Thus, they can run over 90psi most of the time.
The ct will leak oil above and beyond 45psi with out seeing boost in the compressor housing.
supraguru05
Dec 16, 2005
737
louisville ky
what size restrictor would you recommend jon. the line is -4 an, so a 0.060 restrictor would reduce the line ID quite a bit
