ct26 and tubular manifold?
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
Agreed. At that point you might as well slap a T4 on the tubular. Not to mention I haven't seen many designed to be ran with an internal wastegate.
BrandonW
1,300
N.J.
didn't hks make one for the ct26? (maybe it was for that hks turbo that had the same bolt pattern as the ct26)
but for the hk$ price and the slight gain you got it wasn't even worth it
Would need to make a new downpipe, new lines, ect...
The stock manifold isn't the restriction so it's not going to make more power...
Naw, it might spool a little quicker in theory, but a good BPU 7M will spool around 2500RPM as is so it's pointless and a waste of cash.
I know of only one person that did it....and he's from Florida as well...
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Shoot me, but I've considered it.
My reasoning,
I have an SSAC manifold
I have a 57 Trim CT
I have a Defcon DP that I tore the flex section off of, can easily be modified to work
I have a set of SupraSport CT oil lines
Coolant lines are easy
All it requires is a T4->CT adapter, which is easy.
But, I don't really have the time to do all that for no real gain, other than sound, perhaps.
supradjza80
Mr. Formula SAE
Apr 24, 2007
782
Appleton, WI
www.uwracing.com
You guys forgot the most important reason, SOUND...tubular manifolds sound way better than our stock log style mani.:)
With that said, just use a different turbo if you are going with the tubular manifold.
