Cracked Head vs BHG
PlatinumTracks
90
CA
Don't know shit about cars...
but before i fork out my money to go fix a BHG I dont wanna find out later on down the line that it was a Cracked head or block..
is there a way to tell the difference?:1zhelp:
PlatinumTracks
90
CA
Cuz white smoke doesn't come out the exhaust no more just starts to overheat....
it basicly runs fine untill you hit the block a couple of times and then the temp gauge gets to jumping and i cut it off...
figgie;1320193 said:
no there is not unless you have it magnafluxed or x-rayed.
Though with that said, i have seen very few cases of a cracked head or block.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
can't magnaflux aluminum, but you can do the block. to determine whether your head is cracked, you'd need to do a dye penetrant inspection.
a good shop should do these inspections upon disassembly.
