Hi All,
My wiring on the socket (that goes to the CPS) is giving me real pain as two of the 4 wires on the other end of the clip (furthest from the CPS don't seem to be in properly and I have trouble starting the car sometimes if the wiring isn't where it should be. Once started it's all good and fine and i've gone past to an auto elec I know an dhe said he'd need to get another plug and re-wire it...
Can I bypass that plug with the appropriate connectors and have the correct wires going to each other?
(Just incase there is some fuse or something in the plug or if wires interchange, The auto elec pulled the plug open but for the life of me I can't get it open even with a flathead screwdriver pressing down on the part...)
Here is the pic (as you can see on the black wire on the opposite end of the plug it's somehow been pulled it seems from previous owner??? where not all wires are going into the socket properly.....):
If it's doable which wires do I join with which apart from the obvious?
