Would not Having a Thermostat Keep the engine from pulling from the Reservoir?
Car Runs fine keeps temp, doesn't fluctuate or anything like that but It seems to not pull from the reservoir. after driving it will spit fluid out the overflow tube at end of reservoir. Not a ton but eventually after a month of driving and parking it will need fluid added because of the little that will get spit out each time.
I picking up a thermo for it finally. haven't had a lot of time with the car this year. I just wasn't sure if not having it would cause this to happen, or if it was a cap issue
Thanks
Thanks
