Count Knobula said:
I topped off the radiator. Where's the overflow? (89, turbo) And when you say float do you literally mean something bobbing up and down in there?
(dumb lolol)
Just looking at the TSRM. It might be the actual reservoir as opposed to the radiator. So I don't think I have a leak, what could have happened?
The reservoir or over flow bottle has a float and yes it bobs up and down. My 89 had some gunk all around it, I think it was were it had been sitting for forever and the water/antifreeze/other chemicals just hardend around the float and it wouldnt actually float anymore. So it acted like there was no water in the reservoir. You also could have a leak, the rubber around the over flow is probably done its time, just silicon it up and it will hold like new again. There is no real pressure on this bottle so dont worry about it coming out. Its easy to take out, but a pain in the ass to get back in, a screw driver and pacients(SP?) helped me. Don't get frustraited, cause it is a bitch.
kntmikado said:
Not to get off-topic, but what did you clean it with? My float works, but the bottle's really dirty and I'd like to get rid of the ugly dark staining inside it that's keeping me from seeing the actual level.
I just used some a-jax and soap and water, I also removed the float, it comes out but is a pain to put back in and chances are the rubber is shot to hell. Once I cleaned it I just got some silicon calk and popped the float in and sealed the bottom with the silicon. Works like a charm now.
madsupra88 said:
You can use carb cleaner! it cleaned mine like brand new.
Carb cleaner FTW, lol. Hey, whatever works right?
