just got finished building my motor.
Now i have to fill up the rad once in a while.
no visual coolant leaks.
However, i took off the crank case going to the intake pipe and there is a little bit of coolant there.
also, a little bit of junk under the oil cap.
now this motor has 1200km on it.
headgasket is a cometic with all the rivets removed (suggested by my motor builder), the head was drilled for a coolant passage near the # 6 to keep the temps down.
it was also torqued down to 106ftlbs.
any suggestions?
i plan on doing a compression test tomorrow, and test the coolant for and exhaust gases.
really annoying problem especially since it was just built.
any suggestions?
