Compression Test
daught
64
Oakville
I just did a compression test today. My book says the compression should build up quickly. What is quickly? How many strokes?
Also how important is for the engine to be at operating temp? I rather not work on a hot engine...
Sep 10, 2007
482
Virginia
compression should build up after 3-4 revolutions, once the gauge on the needle stops jumping. also, the throttle should be held wide open and the EFI fuse pulled while performing the test.
doing the test on a warm engine gives the most accurate results. a cold engine will give you lower numbers.
what were your numbers??
daught
64
Oakville
Well I only got to do one piston. My friend who was supposed to crank had to leave :3d_frown: On a cold engine I got 150 after 4 revolutions. I will do the rest of them tomorrow but 150 on the first looks encouraging.
Sep 10, 2007
482
Virginia
yea 150 is very encouraging, especially on a cold engine!
it looks like 156 or higher is ideal on a warm engine, and 128 is the minimum.
check out the TSRM:
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?S=EM&P=20
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I did it on my turbo and just wore some "mechanix" gloves and it wasn't a problem with the heat.
The compression results on the other hand were problematic... lol.
Still need to test the NA. Might do that this week...
