Cold Start Injector
Timmie_g
Portugal Cove, Newfoundland
This is just me being kind of curious.
Exactly how important is the cold start injector?? My car is a dd in the summer only, she doesnt see winter weather, and i was thinking about the possibility of running meth injection to the cold start injector and using it as a boost cooler.
Im assuming someone has thought of this before, because no idea is original anymore.
Please feel free to tell me im completly wrong and it will never work. Im just curious mainly.
I know it would all depend on the volume of the CSI as well as the pressure running to it if it is at all possible to begin with.
Thanks
Tim
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
Ive stressed this idea a long time ago in several threads. I don't know of anyone else suggesting the idea on this forum though for use in our cars. Not my own idea either, but i know the concept works thanks to some time I spent on a camry forum an even longer time ago. CSI isn't all that important and can be done away with. I've never heard of meth though, only used for water injection, not sure how it would do with meth.
edit: refer to post below
ebondragon87;1566098 said:
Seen many Toyota's fire up just fine without a cold start injector. You will be ok if you remove it.
Did you bother to read the OP's post and question at all? :nono:
Tim: While in theory it would work the CSI isn't going to flow enough to be any more than at cruise cylinder cleaning (might be different if you can pump 2>300+ Psi into it) but control would be a huge problem as it's only ever going to be "right" in a very narrow RPM band and wrong everywhere else.
Proper Water Injection isn't all that expensive these days.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
For reference, this was done by a very well respected member of the camry community. Original thread with additional info here: http://www.toyotanation.com/forum/t79255.html Obviously not a supra, so keep that in mind:
Toysrme said:
Background:
Pre-Ignition, Detonation, Knocking, Pinging along with Dirty, Grimy, Ass-tastic carbon deposits. (which heat up tremendously and also cause pre-ignition) It's hard to put together two things that will hamper performance, and destroy a running engine in a shorter span of time!
There must be a way to easily defeat them both, without compromising performance, and reliability.
Theory:
Enter water & water/alcohol injection! We'll skip technical detail for a short list.
Water injection suppresses detonation like no other. It accomplishes this in three basic ways:
1) The incoming air charger is significantly cooled by the atomized water
2) Combustion chamber temperature, if a larger amount of water is injected, are lowered.
3) The water cleans off carbon in the intake track, while the steam created in the combustion chambers blasts carbon off parts clear into some of the exhaust manifold.
Because of this, depending on the amount of water / mixture injected, the octane rating of the fuel is effectively raised 15-30 points!
How much water is needed? Well. That is a loaded question. Typically, you add your mixture, which is now both fuel AND WATER and take 12-25% of that.
Water/alcohol injection.
Short and sweet! Adding up to a 50% alcohol ratio to the water will increase it's charge cooling efficiency. We do *NOT* NOT NOT NOT want to injection alcohol as an extra "fuel". IT DOES NOT WORK THIS WAY!!!
There are three types of alcohol you can inject: Methyl, Ethyl, and Isopropyl.
Isopropyl (rubbing alcohol) CAN NOT BE USED!!! It *will* try to burn during the combustion process and suck a significant amount of oxygen from the gasoline.
Both Methyl and Ethyl WILL NOT burn in a majority gas combustion process... It's next to impossible as they are under their lower explosive limit (the ratio of air to fuel needed to combust). Isopropyl WILL try to burn, as it is just above it's lowest explosive limit. That causes the mixture to be extremely rich.
That leaves us with methyl, or ethyl alcohol. Throw out methyl! It eats Aluminum over time!!! That leaves us with regular ethyl alcohol. It can be bought in paint stores for $10 a gallon.
Instructions:
Sadly, you can't just go out and buy fuel injection parts. Water conducts electricity, and the Alcohol will eat away at gasoline safe parts. You would corrode a fuel injector shut rather shortly. Noone wants to rebuild an injector every month :\.
Thankfully! Toyota has given us a gasoline injector that *CAN* tolerate water! The old style Cold-Start Injectors!!! They consist of nothing more than an atomizer, and a solenoid to open/close the injector.
Now we have two upsides, and a downside. On the good side, unlike just buying an atomizer nozzle, when the injector is turned off, boost will NOT flow down the injector/water will NOT be sucked out by vacuum. This is a simple injector, NO DRIVING equipment is needed!!! That's also the bad news, being a simple injector, it's either on, or off with nothing in between. If you don't like it, you can simply cut the shaft off and use it's atomizer.
What does a used cold-start injector cost??? Try $1.50 on ebay. Less than $5 shipped! (2vz-fe / 3vz-fe CSI's are fine. The 2vz-fe injetor is 1 1 /2" longer, so I would take a 3vz-fe injector before that as it would have an easier time fitting in the middle of the intake.
The flow rate for a clean injector is around 150cc/min (OF GAS, NOT WATER) at 30psi.
What do we do for a water supply? Seeing how engine bay space is at a premium, and we all-ready have a 5 quart water supply installed; al-la washer tank. That's the supply!
Water pump. originally I bought a windshield washer pump. (again, used Toyota part shipped for less than $5 on ebay) Unfortunately, this does not deliver enough flow for a boosted setup on it's own. I couldn't use it. I am sure if you bumped it's voltage up to 18-24v it would be a *perfect* pump to use!
So... I was forced to drop a spare gas pump I have laying around! All 80lph of it. It's hard to find information either way about submerging a fuel pump in water, and pumping it. Then again it's a spare so I don't care what happens.
I have simply hooked both the pump, and injector up to a 40 amp relay (again, bought on ebay for $2.50, shipped for $4). Which is triggered by the switchable ground on my SMT-6. This way I can trigger it by any combination of the following: Throttle position, RPM, A 0-5v source, another 5v source. (such as, a map/boost sensor, and temperature sensor)
For anyone *not* using an SMT, you could do something like using a boost switch. They're typically found in 1-4psi, 5-14psi, 14psi+ versions for $15-$25 new. This isn't the best way to do this as the water would be trigger many times in normal driving when it shouldn't.
Originally, the flow was simply insane! The water pressure in the line must have been phenomenal as the 150cc (gasoline) CSI was flowing somewhere around 600cc/m !? That's the flow you would want around 450-550hp on a boosted engine!!! It could empty a one gallon milk jug in just over 4 min!
Something had to be done! I used a smaller line to restrict water flow, and a smaller line to restrict water intake. Now we're down around 450cc/m as It takes just over 60 seconds to empty a 20oz coke bottle!
Eventually, I will wire a large potentiometer to lower the output further at a later time.
This particular digi-cam has a hard time picking out the water, since it's installed, I can't take it out and put it against a bright backlight on a black background. So we'll make do!
One other thing worth mentioning... When you're on boost running water injection, you have no reason to fuel past your peak power. (typically 12.5) The water is doing all the leg work of cooling the charge, and much better at controlling the pre-ignition in the combustion chamber than vaporizing gas is!
ebondragon87;1566107 said:
Sorry, remove it from the fuel system is what I ment.
I understand that's what you meant but what does that have to do with this thread and the OP's question?
Normally this sort of post in tech would earn you an infraction...
arknotts
formerly ark86
Jan 9, 2008
461
Ohio
I don't have my CSI on my FFIM I just installed (although I had the flange welded in so I can install it whenever I want ;) ). Honestly it doesn't start that great at any temperature colder than about 60 degrees. I always have to give it a rest and crank it 2-3 times before it catches and fires up. On a warm motor that's been running it starts perfect. For me, I'm planning on installing it again while I'm on the stock ECU. I'm sure you could get away with it though if you wanted to run meth injection from it (if that's even a viable option as IJ. mentioned). I've got it started at near freezing temperatures, but it didn't like it very well. Just my 2 cents...hope it helps.
Timmie_g
thanks for the responses guys, all the info was appreiciated.
IJ: Yea, I know proper meth kits are usually pretty affordable now days, I was just kind of wondering for my own knowledge i guess. For the time being i didnt plan on running water/meth injection i just wondered if it was possible in the future.
Iwant: Thats pretty much exactly what i was talking about. I'm glad to see I wasnt completly out to lunch with this one.
Overall I know that the CSI can potentially be used for alternate things, perhaps Nitrous if someone really wanted too. Would keep a very low profile as well. Me personally I'll never use the stuff i think its way to hard on a motor but thats just me.
Thanks again guys
8,871
Thanks
Tim
The cold start injector is about starts that are not hot, also called cold. It has nothing to do with winter. If you read these boards you will find many threads with problems, and you will find many threads with people who have taken things off the car it doesn't need.
If you are stand alone and have cold start enrichment, then you could use the injector for another purpose, but that part is not for me to comment. And it has already been touched on.
tsuprat
new york
I have thought for some time that I needed a new CSI. The car hardly gets driven anymore. I like to spend more time in it/on it. Someday. When I do start it cold it stumbles till I give it a lttle gas peddle easy, then it catches and runs fine. Is that the CSI or dirty from not being run very much? Thanks
sabinrc
niagara falls NY
I have a 91 Turbo. I have the Toyota Manual. I am trying to locate the Cold Start Injector in the engine bay. There is no picture of the location in the Manual. Can anyone help??? Reason:
On a cold morning I have to really crank the engine for it to start. Once it starts its ok after that. So I am thinking CSI. or maybe Fuel Pump???
