On my pre 89 harness, 7mgte MK2 auto, I have had a continuing code 51 and an occasional neutral start issue where I would have to shift it to neutral or so in order to start.
But the codes 21 & 42 (along with the 51) showed up after MPG went to 13-15 mpg from 19-20 mpg on 2 tankfulls. Strangely, pulling the EFI fuse wouldn't reset the codes. I replaced the old O2 sensor with a new one and tried the EFI fuse pull to reset the code. It didn't work. Today, I did the battery ground disconnect and the codes reset except the 51. I had the AC turned to off.
1. Why did the code 42 get reset with the O2 sensor change? I haven't rechecked the codes after some short drives.
2. For the code 51, is it more likely the TPS setting or do I have to mess with the neutral start switch?
