Hi All,
I have problem with my car after a BHG repair, when the engine is running the AFR is lean, the voltage in Vf1 is always 0.01, If I turn off the engine few seconds and then turn on the engine some times the VF1 voltage change to 1.90~2.0, the AFR change to 13.9 ~ 15.1, but after some time of driving the car begin to hesitate.
Get code 14, I want to know how to test the wiring from the ecu to the igniter.
I don’t know how to rewire because the wire color change from the ECU to the igniter can some help me?
Thanks and regards.
Thanks and regards.
