clutch install problems
1jzsupraguy
33
Milwaukee
when i tighten the flywheel down, i can't spin the flywheel anymore. usually when you're tightening the flywheel bolts down, it comes to a certain point where you have to prop something to keep the flywheel from spinning but in my case i dont even have to. anyone have any suggestions?
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
ya, get a socket on the crankshaft bolt have someone hold it and you torque down the flywheel bolts. If you motor is spinning freely then you messed something up. Like maby you dont have internals? But do as i say and you flywheel will be tight.
Edit my bad, i didnt understand what you ment. So you cant turn the motor freely? Can you feel the compression?
