Hey guys, I did a search, couldn't find anything, and so I have a simple question. The mode select buttons on my climate control are not staying pushed in when i try to change modes between like, top vent, bottom vent, both vents, def/bottom vent, and def. is this a common problem?
also, my LO fan setting does nothing. it's like i turned it off.
i'm pretty good with this kind of thing, do you all think it would be possible to fix it? Or would I just need to swap it out? Or could it be something else? I saw one post (I think by IJ) about a bad switching assembly in his system.
Thanks!
Charlie
Thanks!
Charlie
