I want to change my coolant before spring. I've bought 8liters of red coolant. Right now there's unknown green coolant in the rad. So do I need to take some special notice before changing? As I understand, I just need to loosen that lower radiator bolt, and then fill it with new coolant, right? Or do I also need to find drain plug in the block?
Is there anything bad if I'll mix some green coolant with some fresh red one?
P.S. I did search on coolant change, but came up with nothing, so I started a new thread.
