Changed wastegate and spring. now it over boosts aem ems v2
nathaninwa
377
Aberdeen, WA
You may have said in your other post, what kind of boost control are you using? AEM? open or closed loop? If open loop your DC numbers will be really low to only get 2 more psi, plus your ramp in, if set higher will mostly likely need be dialed out. Did the new gate get rid of creep? Will it hold 14psi with boost control off?
