CAS mod for MS-II (Complete Writeup)
gennro
357
Alamogordo, NM
Nice man. I would rather get rid of the CPS and plug the hole and run a 36-1 EDIS 6 setup. This would be a bit cheaper setup though.
This needs to be moved to standalones section and stickied.
Oh hey you are from VA beach. I'm up in Hampton btw.
HeadTrip
11
Virginia Beach
www.saturnwiki.net
grimreaper;1555952 said:
NICE! does it work?
Does the ground off tooth have to be aligned with the gear for the cam?
Not in the car yet, but it works great on the bench. And yes the ground off tooth needs to be 10* BTDC, or however far BTDC you tell the MS it is at least. I went with 10* but the MS is pretty damn flexible in that respect.
empera
Authorized Vendor
Philly.
gennro;1561422 said:
Yes as long as it supports 24-1 missing tooth wheel.
yea im def. not the most knowledgeable on the aem (or any ems) but im sure it would be able to do this....i'm having trouble with my cps now so this could come in handy.
