I can't figure out what I did wrong on my reassembly.
1991 N/A with a JDM 7mge, W58
Symptoms:
Coolant gauge pegged to hot once battery is connected
Cold start injector runs constantly once start is attempted
Cranks strong, but does not catch, won't start.
What I did to get to this point:
The engine was leaking a lot of oil from many places, so I decided to just pull it out and replace all of the leaking seals. (oil pan, cam covers 1,2,3, rear main seal, distributor seal, valve seals, etc...) I also replaced the head gasket, and had the head machined and compression tested while it was off. Head gasket re-installed with ARP head bolts torqued to 93. Replaced the water pump, timing belt, thermostat, spark plugs, wires, and distributor cap. I used Cygnusx1.net and the TSRM for all of the repairs.
Timing checks, I'm getting spark and fuel. All of my fuses and fusible links appear to be intact.
Everything worked before I took it apart, so I know I must have done something wrong, I've searched the forum and haven't found these symptoms.
I'm in pilot training for the military right now and am just about to the point of towing it to a shop and having them look at it. I'd rather get some help and learn from my mistakes (whatever they may have been).
Thanks in advance for any help and insight. I'm sure that I'm just missing something obvious.
Symptoms:
