Right, I knew which sensors you were talking about, was just unsure about the condition of yours. So no connectors at all? That sucks...you might be able to get those from Toyota (I know they sold CPS and KS pigtails, not sure about others), otherwise I'm sure someone with a part-out going on will have them.
SickSupra;1586923 said:
I read that if the sensors getting a false reading (the guy had just the yellow wire wrapped around the sensor) it will whack out the ECU and make the car act up..Also did a fresh coolant flush today and drove it around for about 10 minutes and all of my coolant was gone, but I have no leaks at all...
As far as the "ECU Coolant Sensor"...yes, the ECU uses its signal (THW) for many functions including fuel and spark corrections, etc... if there is no signal from it, like in your case, the ECU enters a fail safe mode (hence the code 22). When this happens, a certain fixed temperature is assumed for all calculations...obviously not a good thing when it comes to performance.
The "Instrument Cluster Coolant Gauge Sensor," on the other hand, has zero effect on how the car drives; but it is arguably just as important if not more, since without it you won't know if you're overheating. You should
really not be driving your car without a way to know its temperature, especially with your known low coolant level; I can't stress this enough...
So how did you determine that you had no coolant? Did you open the radiator drain cock and nothing came out? (could still be coolant in the block) Or were you just looking at the overflow reservoir? Reason I ask is it's highly unlikely you lost
all your coolant in such a short drive without a massive and obvious leak; even a bad BHG wouldn't do this...
