Okay here is what happining. Fresh motor with a 1mm oversize pistons. All new. I only just started it and only put 3 miles on the motor already. Im pretty sure I still have to seat the rings but I dont think it should be missing like it does. All spark plugs,wires, and coil packs are good. CPS is good. I have checked all wiring & connections for Ignition so I think its somewere else. I did find a fuel leak on #6 injector. Really bad O ring went bad. Fixed it but still have the miss. I did see fuel coming from injector #1 but not really bad. So I need some more help narrowing down more causes.
The CPS is on Basic Timing as it says here http://www.supramania.com/forums/content.php?181-How-To-basic-timing-instructions-CPS-alignment
