i know this is a long shot, but i'll post it anyway.
recently, i put in new rc 550's in the car with the lexus afm and went to try to get it running like it did on the old 550's. which was about 19-22 psi on the .57trim ct.
well, the car wouldn't boost over 11psi with the new injectors, so i knew there was a leak. i tested the system and found the throttle body and isc to be leaking. i solved that problem with new gaskets and a little FIPG.
once that dried, i pressure tested the intake system again with 20psi of pressure and couldn't find a single leak. in fact, my tester shot off my accordion pipe several times when testing. i drove the car, and still had the same problem.
the problem is that the car won't boost over 14 psi. it just hits fuel cut, and i can't seem to find a boost leak. i tested the TPS per the TSRM and it was within speck.
fuel pressure is at 40psi with vacuum line off.
screw on lexus afm is backed out some.
the car runs smoothly, and at cruising speed on interstate, the wideband is about 15 and at wot, it is around 10-11.
my mods are listed below, but some important ones are:
walbro
profec e-01
e-manage, but it doesn't work with my vista powered laptop
.57 trim
spearco ic and cooleeze pipes
if anyone has an idea, please let me know. i don't care if you call me 985-264-8884
walbro
profec e-01
.57 trim
