Can u use the R154 clutch in the w58
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
[Strike]Flywheel belongs to the engine. So does the clutch disc.[/strike]
The pressure plate and clutch assembly are a part of the transmission.
Sent from my ADR6400L using Tapatalk
Nope, different flywheels for GE (W58) and GTE (R154).
Disks are interchangable, but they are different sizes. Pressure plate is a definate no.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
You're right actually. I'll edit my post, I had that backwards.
Doesn't the pressure plate and therefore the trans dictate the flywheel? The engine definitely doesn't matter. It's the same crank.
Jacob
the overkillist
Feb 11, 2007
196
East Coast USA
actually I've drilled and tapped a 2jzge (w58) flywheel for a 7mgte (r154) clutch/pp. The N/A flywheel is way thinner. I don't think th R154 clutch/pp would fit in the w58 bellhousing though. pretty fuckin big. And a note the pedal may act different and/or need adjustment because of the difference in thickness of the flywheel.
Look it up on here like 3 years ago. There's at least one other person who did it.
