can safc do 780cc injectors,
ahmed
150
cleveland
i have a set of 780cc injectors wanna know if i can tune it with just an safc. ill be running at least 20 psi on stock 1jz.
JimR
Canada
Hahaha! For real? :)
Let us know if you get er idling with that thing. I will be very impressed.
Aren't you a little worried about the lack of timing that the ecu will pull, because it has no clue that you're sucking in 77% more air and fuel than it thinks you are?
jza240sx
Formerly jz240kouki
Jul 18, 2009
185
New Jersey
in my opinion i would go stand alone but like JimR says if you get it idling id be impressed. prove us wrong!!
87targa
200
Utah
I had 750 with an safc and it worked fine on a 7m. i did have to lower my fuel pressure drastically to make it idle though.
JPsToyota
231
East-Central, FL
prototype_HI;1441831 said:
^ spray pattern meaning inconsistent injector shots due to lack of solid fuel supply?
I think he's referring to the way the fuel injector atomizes (is atomizes a real word?) the fuel into the incoming air. With a lower fuel pressure the fuel spray may not leave the injector as intended and may not mix with the air properly.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
Yes, i am running 820cc. my idle is fine. Even with Cams.
I do have to pull 46% fuel at idle but it was able to and
runs just fine.
JPsToyota
231
East-Central, FL
runs just fine.
What kind of fuel are you pulling for cruising? Or hi throttle low rpm? Just a ballpark is fine, I'm just curious.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
My Fuel pressure is set to 45psi. I am pulling 46 at idle and gradually goes up to
-30 at 6000rpm.
My low position trottle is at 25% and hi at 60% <--some ppl have it different but this has worked for me for the past 4yrs.
At hi throttle, It waivers from -30 to -10 in the 3500 to 5500 range and by 7200 I was at -4.
But be sure you tune according to you specific altitude and particular set up.
I just recent changed up my set up again and this did not work at all. I had to redo the whole thing.
