cams for my 7m, 500-600whp powerband
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
OK guys so I am getting ready to order a t61 garrett/comp turbo from a fellow member on here and I am looking for the right cams to run for the best powerband on this setup...I have a built 7m now and am tuning for pump gas and a e85 setup I plan to put down 500 to 550whp reliably maybe 600 max!...any suggestions on the best cams to run for this?
ohiosupramst
138
Cincinnati
I know I'm going to be running sip stg. 2 billet cams on a t66 on e85 @ 25 psi. I don't think youll be able to reach 600 whp on a t61. Look at a 6265 or 6265 if you want 550+ whp. The regrind cams that sip sells aren't to bad either.
turbo87targa
482
colorado springs
I have TED 268 cams taken off a 800whp 7m for sale. PO told me they brought a 1000rpm quicker spool on a gt47
Less than 3000 miles on them.
Also the springs and shims
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
i will let you know turbo87targa i might be going 2jz not decided yet...my setup is actually just going to be my 57 trim ct26 built 7m as of now if those cams will work good for my powerband shoot me a PM
Stock cams are pretty much the best for a 57trim. It runs out of breath at 5500 so cant really use any sort of cam with it.
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
yea i know the ct26 runs out quick up top haha im hoping to make some good numbers though! gonna be running aem standalone seeing how much i can pump out of it then I would like to go 2j just dont know if the funds can support doin the swap lol :/
For the money spent on the aem and tuning alone plus cams is almost enough to do a 2jz swap.
Also revving to 7k with the ct is not good for the motor. Puts too much pressure on the motor not allowing the exhaust to flow.
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
yes i agree on the aem and tune costing as much as a 2j swap...thing is, i think someone will want to buy a 7m full swap that has a nice standalone and tune rather than one that isnt tuned and isnt exactly running to swell...that will be my dilemma is how much i get out of my 7m will determine what i can do ith the 2j swap :/...ill stick with stock cams as you said though thanks for the info on the ct26!
8,873
I think you are better off doing bowl work and the 1mm oversize valves. The cam accomidates the head, not the other way around. Yes, I know many do it the other way. They use a big cam to make up for a crappy flowing head.
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
yea man i see what your saying, im debating i know i wont have the ct26 setup much longer and i really want to push the 7m if not go 2j...i would like to stick 7m and build it like duanes and make massive power still stay true to the 7m though
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
anyone know if i would be better off staying stock cams or upgrading for my holset build up? gonna be pickin up a holset hy35 or he351 very soon and am looking for 500whp possibly 520whpish but these will rev higher than my ct26 so didn't know if i should upgrade the cams for higher powerband or not? they would have to make a difference than stock ones
I would up grade cams if your going to be at that power level. Also need cam gears and to get them dialed in and tuned.
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
ok yea thats what i was thinking, probably 262/264 cams no need for 272s, titan has some good cam gears for the 7m as well ill have to look into
