camber kit???
drod23
60
Santa Paula, California
i have excessive negative camber in the rear and i wanna get a camber kit
i bought some from horsepowerfreaks.com made by a1 racing and when i was aligning my car it was adjusting the toe...
so were can i get a kit to fix the camber......??
supraguru05
Dec 16, 2005
737
louisville ky
you probably bought the toe link instead of the camber arm. There are two arms running semi parallel to the axle. you need to replace the one that has a U shaped connection on the hub. It is the large square link, not the link that the sway bar attaches to.
