Cam Card Database
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
after my other thread, its become apparant that its nearly impossible to compare cams just by name and manufacturer. most people end up wanting one came due to its namesake but buying another because of its price tag or foregoing that cam for a regrind from a 3rd party because it seems possible to get the same cam as the 1st (expensive) option at a fraction of the price because it has the same "name"... only to find out its not the same animal. i think we need to start a list of cam cards for future reference so we arent just playing a name game when it comes to picking cams.
how bout this format for entering all the pertinant info (or a clear picture of your cam card);
MANUFACTURER:
PART NUMBER/WORK ORDER:
ENGINE APPLICATION:
ADVERTISED SPECS-
INTAKE DUR / LIFT / CLEARANCE (LASH):
EXHAUST DUR/ LIFT/ CLEARANCE (LASH):
RECOMMENDED VALVE SPRING INFO-
PART NUMBER:
VALVE CLOSED PRESSURE:
VAVLE OPEN PRESSURE:
DEGREEING INFO- (SPECIFY IF NUMBERS FOR SEAT-TO-SEAT OR 0.050")
INTAKE VALVE OPEN:
INTAKE VALVE CLOSE:
EXHAUST VALVE OPEN:
EXHAUST VALVE CLOSE:
LSA:
DURATION @ 0.050"-
INTAKE:
EXHAUST:
LOBE LIFT-
INTAKE:
EXHAUST:
NOTES: say a few sentances about your cams and their operating characteristics. IE: idle quality, ease of degreeing, power band, etc.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
Since i dont have cams for my 7M as of yet, ill post an example using the cam i have for my 79 Trans Am 6.6L
MANUFACTURER: Crane Cams
PART NUMBER/WORK ORDER: WG1014
ENGINE APPLICATION: Pontiac 265-455
ADVERTISED SPECS-
INTAKE DUR / LIFT / CLEARANCE (LASH): 308* / 0.469" / 0 (1.5 rocker ratio)
EXHAUST DUR/ LIFT/ CLEARANCE (LASH): 320* / 0.469" / 0 (1.5 rocker ratio)
PART NUMBER:
VALVE CLOSED PRESSURE: 120psi
VAVLE OPEN PRESSURE: 300psi
DEGREEING INFO- (@ 0.050")
INTAKE VALVE OPEN: 2* BTDC
INTAKE VALVE CLOSE: 48* ABDC
EXHAUST VALVE OPEN: 54* BBDC
EXHAUST VALVE CLOSE: 6* ATDC
LSA:
DURATION @ 0.050"-
INTAKE: 230*
EXHAUST: 240*
LOBE LIFT-
INTAKE: 0.3129"
EXHAUST: 0.3129"
NOTES: Largest hydraulic cam possible while still maintaining vaccum assist brakes. Regrind of original 1970 Ram Air IV "T" camshaft. redline of 5900rpm. poor idle quality and strong mid range. recurve distributor, large stock carb or aftermarket unit. aftermarket manifold, 10.5:1 to 11:1 static compression, mild port work recommended. manual trans or high stall converter to be used. final gears of 3.90-4.50.
PS: the card didnt have the LSA listed. is there an easy way to figure it out from the valve events?
