c02 spraysystem for IC?
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Volusia county,Florida
does anyone out there know where I might find a c02 spray bar cooling system for my intercooler?
I saw one installed on a 350z on FineTuned on the speed channel,pilot episode. They claim it will increase h.p. 20-75%. Eitherway it looks pretty cool. :biglaugh:
While I have your attention, will the stock intercooler suffice if I am going to be running 14 psi on stock c12a's? any suggestions?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i would suggest an aftermarket IC, the difference is huge on spool time and boost (i used spearco replica, check the review section)
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Thanks! any suggestion on size? I'm not building a track car, just a badass street machine.:icon_bigg
I can't believe no one has any input about c02 system, ANYONE???
tlo86
Jul 24, 2005
3,914
Colorado
i bought the spearco replica its about the same size as the stock one just thicker and a much much much better design. and it was cheap too :)
i have seen systems but they arent cheap, your best bet is to piece it together hehe. think i saw something on horsepowerfreaks.com i wanted to do this as well but i am just going to use a water sprayer, it will help with horsepower a lot but thats when you are having high power numbers i honestly wouldnt see a huge benefit at lower power levels unless you are on a long drive~
but thats kind of why im doing the water :) just like the sti's ic sprayers just incase i do have a long drive
Divin' Devin
Supra Extremist
Oct 8, 2005
145
tlo86-
I found a system on suprasport.com. Look in the intercooler and pipes section. They also have the water sprayer system. Thanks for the info on the intercooler.:drink1:
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
My friend built his own with a few trips to Sports Authority (20oz co2 bottle and remote line) and a few trips to home depot.
Divin' Devin
Supra Extremist
Oct 8, 2005
145
Not bad! Any way of getting plans for the home built? I figured it could be done; just didn't know where to start. Also, when I get done would I find it would have been better to have bought it.
foreverpsycotic said:
IIRC, it cost him <100$ to built himself
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I call BS!!!!!!! A 75% increase to a 400hp car would push it to 700hp! By spraying an intercooler???????? I think NOT!
Now a 20% increase over the stock HP would be about a 40hp gain. Maybe that's obtainable
HIDPLANET
89 1JZGTE
There was an interesting article once upon a time that tested spraying the IC was various substances as well as running a high power fan to replicate driving conditions for the airflow. Performance was not impressive for as much time it takes or money spend on the spray systems.
I was considering fabbing up a WOT switch to a spray system but decided not to after reading the article.
Anomili
Obsessed
Apr 9, 2005
371
In an Igloo
What did he use for a solenoid? These are the parts that cost a lot. It is the mechanism that blocks the co2 from flowing when the button/WOT trigger is not depressed.
I have designed my own set of pipes, bent in the shape of an S and punched with holes. The reason I could not complete the set-up was because of the cost of a solenoid. As well, the cost of a decently sized canester is over $100.
Normal systems go for around 400 CAD. I would recommend looking at any NOS system manufacturer as they tend to also sell CO2 systems. Also, search "cryo"/"co2 sprayer" in google as I forget the exact name of a couple companies with that in their name and am too lazy to do all the research again.
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
I have the spearco FMIC replica from drift motion in a 7MGTE running 10psi on stock ct only other mods are boost controller exhaust turbo back 3 inches and an intake, also minor things like electric fans and hardpipes. The IC made a nice difference in spool time and pull especially at mid and high RPM's also seemed to eliminate lag on hot days after the cars ran a while and soaked in the heat.
I don't think the sprayers are all that worth doing, you're adding weight and gaining a slight increase in power but not really that much, after offsetting the weight gain of the system I would bet the power gain is barely above breaking even. Some people claim its bad on the IC as well because of heat shock, that one I'm not sure of but just bringing it up since I've heard it from numerous people of different forums.
empera
Authorized Vendor
Philly.
could c02 be used in a no2 bottle...since i have an extra empty nos bottle and i wanted to try this system out...unless i should just use nitrous on the IC.
Divin' Devin
Supra Extremist
Oct 8, 2005
145
I also wondered about the shock to the intercooler. I guess I need to find a product rep. and see what they migtht say.
Thanks for all the usefull input.
Would electric fans on the FRONT of the intercooler be a reasonable option? Or would the main fan cancell it out by pushing from another direction? Especially since I'm going to keep my hydrofan.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
he uses a paintball remote line with a 20oz co2 paintball tank. you turn the screw to turn the c02 on. he uses it inbetween auto-x runs and highway pulls
