So i installed a new brake master cylinder the other day and the problem is that the second hole that the second brake line connects to the master cylinder the one closed to the brake booster doesn't piss out brake fluid. The first one hole fluid flows out just fine so my front brakes work fine.
Now i did not bench bled the master cylinder, i did bleed it the way TSRM tells us but i think that makes it worse.
Any suggestions or am i doing something wrong?
