On the brake master cylinder the two brake line connections, is there a front and rear or does it not matter? For the stock proportioning valve, which of the two inlet connectors are front, and which one is the rear? The reason i am asking is because i took the abs out of my car and need to figure out the way it goes. The search, tsrm and chiltions manuals were no help.
edit... or if someone has a clear picture of how they go that would be greatly apreciated. I cant get the hard lines from toyota because alot of them are discontinued so i am using steel braided lines made to fit.
