Brake light/ Tail light not working FIX, EVERY SUPRA NEEDS THIS
pmmfred
York
The brake lights and tail lights on the supra are notorious for failing, if yours are working or havent already failed, chances are the will eventually stop working which cam become very unsafe and illegal. This is how you fix/prevent them from failing. With the help of YotaConnectors.com we got the Supra fixed again LOL.
[video=youtube;rBXw2mefRzk]https://www.youtube.com/watch?v=rBXw2mefRzk&index=7&list=PLytCegeev2Lyg55ZIjfSBpOCotv3YM_WN[/video]
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
Just as easy to just repair the high current path circuit within the sensor box.
Usually just a bad solder joint, or jumper wire.
If the IC chip on the board is still ok its very very easy to repair.
Takes about 2 minutes of diagnosis to figure out.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,232
Atlanta
Yup.
I've done the box repair, it was just a jumper wire that needed to be added, to bypass a bad wire.
I'm not big on bypassing the failure box altogether.
Piratetip
1,177
69
MKE, WI
Yeah not a fan of hackjobs that end up removing useful features.
Just comes off as lazyness.
